[OpenLayers-Dev] SVG and OpenLayers
Michael Östling
michael.ostling at metagis.se
Fri Jul 27 03:46:04 EDT 2007
I have questions about functionality and services around OpenLayers.
I would like to do a small prototype on some of the functionality in
OpenLayers.
I do not have the sparetime or deeper knowledge on OpenLayers to work on
this myself so I ask if there are resources out there who can do some
consulting work.
Im sorry if its the wrong place to ask for this in this forum.
Most of what I need can be found in the examples that are delivered together
with the source. But Im not sure how to fit it all together.
I need more documentation to do that myself.
What I need is the following:
A Background Layer that uses my own ESRI ArcGIS Server Map Cache. This is
done and works nearly perfect.
On top of this I need to show points, lines and polys that should be
rendered with SVG.
This data are stored in a database-table on the server. This data are
dynamic and should be updated every 15 second.
For each object I need to have a mouseOver and mouseClick Event to show a
tooltip. Each object should also be differently rendered with symbols
defined by the data in the database.
Possible extra step:
As a separate prototype or just test of concept I would like to integrate
ESRIs WEB-adf for ArcGIS-Server with OpenLayers capability to render objects
in the client.
So I would use ESRI WEB-adf to draw the background Map Cache. On top of this
I would like to draw dynamic data with SVG using OpenLayers as decribed
above.
Perhaps this is to complicated to do.
I f you have ideas or suggestions on this and have time to spend, please
send me an email with your ideas and a budget for your work.
If this is the wrong forum for asking for this type of support please give a
hint on where to go.
Regards
Michael
MetaGIS AB
Michael Östling
Mob: 070-279 19 76
Tel: 023 - 702 20 10
ePost: <mailto:michael.ostling at metagis.se> michael.ostling at metagis.se
Adress: Britsarvsvägen 28a, 791 36 FALUN, Sweden
Org Nr: 556638-7170
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070727/a12f66fb/attachment.html
More information about the Dev
