[OpenLayers-Dev] A new Era of... documentation!
Erik Uzureau erik.uzureau at metacarta.com
Fri Jun 29 12:29:05 EDT 2007
A followup note to this email:
If you are looking through these docs and find something that is funny
or wrong or incomplete or just doesn't quite belong.... PLEASE TELL
US. Just send an email to either users or dev list and we will be sure
to update the documentation.
Thanks!
Erik
On 6/29/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> (Follow-up to users at openlayers.org.)
> So, as of about 15 minutes ago, the trunk of OpenLayers has been
> completely reworked to be documented in NaturalDocs style instead of
> JSDoc style.
> What does this mean for you?
> For everyone, there is now a more complete set of OpenLayers
> documentation, which can be built by anyone, and a full set of docs
> written in that style.
> For users, we now have a set of documentation about what APIs,
> properties, etc. we promise to keep the same from version to version.
> The Properties, Methods, classes, etc. that are documented at
> http://dev.openlayers.org/apidocs/ will not change without a major
> version bump (or, in some extreme cases, a strong majority opinion to
> the contrary, as in the non-working Canvas code that has been removed
> from trunk).
> For developers, we now have a much more complete set of documentation,
> describing everything in and around the OpenLayers classes.
> http://dev.openlayers.org/docs/ In addition, you can generate these docs
> using the natural docs command line tool, so when you're writing your own
> code, you can generate the docs and see how your docs look.
> There are a lot of people who have put effort in, and improving the
> existing documentation is going to continue to be a challenge -- but
> we've now taken the documentation we *do* have and made it available in
> a way that we didn't have as of even 2 weeks ago. Thanks so much ot all
> the people who worked on this, and we're looking forward to seeing what
> happens now that people actually know what's inside OpenLayers :)
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
