[OpenLayers-Dev] hidden control objects
Christopher Schmidt
crschmidt at metacarta.com
Sun Mar 4 13:40:19 EST 2007
On Sun, Mar 04, 2007 at 07:24:42PM +0100, Eric Lemoine wrote:
> On 3/4/07, Eric Lemoine <Eric.Lemoine at camptocamp.com> wrote:
> > Hi
> > I have one problem with the vector branch, which has nothing to do
> > with the branch code per se.
> > When using the single file library my controls (LayerSwitcher and
> > PanBar) are hidden behing my WMS base layer. I know they're there
> > because I can still use them, assuming I'm lucky enough to actually
> > click on them. The problem exists only on the single file library.
> > Does anyone have an idea where this could come from? I'd like to debug
> > it, but doesn't know where to start from?
> Replying to myself here:
> I'd actually forgotten to copy the "img" dir along with the
> OpenLayers.js file. I guess the "theme" and "art" must be copied over
> as well...
Art is 'source' data, and is not needed to run. theme/ is important for
things which are controlled via CSS. Currently, this is relatively
limited, but it will expand in the future.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
