[OpenLayers-Dev] final animated zooming and panning patches
Paul Spencer
pspencer at dmsolutions.ca
Thu Mar 29 14:11:06 EDT 2007
Sorry, I'll try to explain more ... Now using the controls
example ... I'm only using the mouse wheel to zoom one step at a
time. By the 3rd step, it is slowing down and by the fifth it causes
100% processor usage for several seconds to complete the one step zoom.
Browser is Safari, hardware is a powerbook g4.
In Firefox, it is much better and rarely shows the really blurry
tiles (or briefly enough that I can't get a screencapture of it anyway).
Digging a bit deeper ...
initial load: 4 tiles
zoom 1: 10 tiles
zoom 2: 30 tiles
zoom 3: 44 tiles
zoom 4: 50 tiles
zoom 5: 51 tiles
zoom 6: 60 tiles
Each zoom was a single step zooming in using the mouse wheel.
Initially I thought it was keeping all the tiles from a previous zoom
level but it actually seems pretty random to me. Some of the images
are definitely from other scales though and I think the blurry image
is a symptom of those images being left in the dom tree and being
scaled way beyond what they should be. I haven't looked in the code,
but I expect it is a leak of some sort that leaves these tiles in the
dom after a smooth zoom. This theory also explains why performance
tails off quickly as I zoom ... more and more images to resize over
time.
Cheers
Paul
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070329/d7846c1b/Picture2.png
On 29-Mar-07, at 9:49 AM, Emanuel Sch?tze wrote:
> Hi Paul,
> I'm not exactly sure what do you mean.
> If you start the demo; zoom f.e. to level 5 and you drag now the
> slider to
> level 0 you get a new zoomOut tile which show you new informations
> arround
> the last viewport of level 5. This zoomOut tile is 4 times greater
> than a
> standard tile and it contains the max extent. So it comes to some
> alleged
> strange situations if you zoom out from a high level. After mouseUp
> the
> zoomOut tile stay pixelated until the new tiles are loaded. This is
> a normal
> zoom out process. Sure, we could improve it but therefor you have
> to load
> more zoomOut tiles which scales in higher levels - and this could
> be evoke
> new performance problems.
> To improve your own performance try to make your map smaller. My
> demo has a
> map with 100% width; dependent on your screen resolution there are
> many tiles
> which have to scale. Perhaps there is the bad performance effect if
> the tile
> size over 32768px like in IE? Which browser and hardware do you
> use? I can't
> reproduce these effects on my machines. Try the controls example
> [1]. It
> should works faster.
> Regards,
> Emanuel
> [1]http://dev.openlayers.org/sandbox/emanuel/animatedZooming/
> examples/controls.html
> On Thursday 29 March 2007 15:10, Paul Spencer wrote:
>> Hi Emanuel,
>> I just tried this out for the first time and its quite good :) I
>> have one piece of feedback. In all browsers (although perhaps Safari
>> is the worst), there is a strange visual effect after it has scaled
>> the tiles and before the new tiles arrive, some (or all perhaps) of
>> the tiles change to a very blurry image ... its very pixelated, each
>> pixel looks like it is about 50 square pixels on my screen. This
>> doesn't happen right away, only after I have zoomed in a few times.
>> Also, after a few zooms, the whole thing slows down to the point of
>> being not useful anymore and jacks my processor through the roof ...
>> at this point, even resizing the window is horribly slow and consumes
>> a lot of processing power. I've attached a screen grab of the blurry
>> stuff that happens on zoom out.
>> It does work great when first opened, though, so hopefully its
>> fixable :)
>> Cheers
>> Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
