[OpenLayers-Dev] tiling with watermarks + labels
Christopher Schmidt crschmidt at metacarta.com
Mon May 7 15:19:13 EDT 2007
On Mon, May 07, 2007 at 07:24:06PM +0200, Emanuel Sch?tze wrote:
> 1. Some WMS create for _any_ map a scalebar, logo or watermark. If you use
> tiling, it looks really terrible: look at the demos [1] and [2].
> Are there already any proposals to solve this problem?
Don't use WMSes which do that :)
> 2. Another problem of tiling are labels. If you have a label, which overlaps
> the tile border, it will clip and doesn't continue in the neighbor tile. Demo
> [1] shows this effect.
> Anybody already disussed some new methods to improve this?
Sure. That's what meta tiling in TileCache fixes. Same with ka-Map.
(PARTIALS OFF helps in MapServer.) Mapnik changes the problem by using
geographic-based label locations (rather than tile-based), so that the
problem is different -- you just have to make sure your tiles are always
big enough (before you save them) that you can catch any thing that
might lie across an edge.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
