[OpenLayers-Dev] VML Rendering of point data
fporc7ji fporcelli at taic.net
Mon Oct 1 13:10:02 EDT 2007
Hi Chris --
I posted the files again, this time without the entire build. You should be
able to paste into any OL2.5 build.
Regards,
Frank
Christopher Schmidt-4 wrote:
> On Thu, Sep 27, 2007 at 06:38:23PM -0700, fporc7ji wrote:
>> Hi Eric --
>> Here is what I am experiencing.
>> When reading in a KML layer using the VML renderer, the first point
>> displays
>> at the correct location.
>> If the layer has multiple points after the first point is added a child
>> node
>> is added to the root as directed in elements.drawGeometry. As soon as a
>> child node is appended to the root, the first point shifts and is no
>> longer
> I am unable to replicate this behavior. The kml-layer example changed
> from using points to lines before 2.5, but I just tried it with a KML
> file with points, and everything looked the same (barring sub-pixel
> rendering differences) in IE6, IE7, and FF.
>> My attachment has a sample KML point layer included.
> Your attachment didn't make it through. Try again, perhaps?
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
http://www.nabble.com/file/p12983313/VMLIE6Issue.zip VMLIE6Issue.zip
View this message in context: http://www.nabble.com/VML-Rendering-of-point-data-tf4516302.html#a12983313
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
