[OpenLayers-Dev] Problem with Safari on Mac
Christopher Schmidt
crschmidt at metacarta.com
Thu Oct 11 18:07:19 EDT 2007
On Thu, Oct 11, 2007 at 11:29:32PM +0200, Antonio wrote:
> Hi guys,
> I was just trying the 2.5. There are a lot of work done and I want say
> Thanks.
> I am having some troubles with safari on Mac to run many examples. This
> is the first time I am using this browser on this platform (Safari on
> Windows works well) and I don't know if the 2.5 or all old releases had
> the same problem.
> If I remember well there was something as "Safari need to load a unique
> js file, it doesn't like much to load multiple js files".
> Could be this the problem?
> In the example.html when I try to uncheck the Overlay layer "DM
> Solution" it is hidden but when I check it again it is no more showed.
Sounds like http://trac.openlayers.org/ticket/758 , with no known
workaround.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
