[OpenLayers-Dev] auto-generating OpenLayers javascript
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed May 7 13:32:56 EDT 2008
Hi Robert,
you can use OpenLayers.Format.WMC (Web Map Context) for this purpose,
although it's pretty much limited to OpenLayers.Layer.WMS.
If you need other types, you could look at the OWS Context specification
by OGC, but there is no OL code currently for this format. Mapbuilder
does have code for this IIRC.
Best regards,
Bart
Burgholzer,Robert wrote:
> I am interested in developing a parser that would take a block of XML
> describing a map view (maybe SLD notation?) and turn it into
> OpenLayers javascript code. Once I have done this, I would like to
> turn it into a WordPress plugin, so that maps can be dynamically added
> to blogs, real, custom maps that is. The things I think I need to
> know before starting this are:
> 1. Is there already something out there that does this?
> 2. What format is considered the best standard, SLD, or some other?
> 3. Is this interesting to others as well?
> Thanks!
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> rwburgholzer at deq.virginia.gov <mailto:rwburgholzer at deq.virginia.gov>
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
