[OpenLayers-Dev] auto-generating OpenLayers javascript
Cameron Shorter cameron.shorter at gmail.com
Wed May 7 19:43:19 EDT 2008
Erik Hazard is a Google Summer of Code student who is interested in this
work. I suggest you touch base with him and work synergies between you.
Bart van den Eijnden (OSGIS) wrote:
> Hi Robert,
> you can use OpenLayers.Format.WMC (Web Map Context) for this purpose,
> although it's pretty much limited to OpenLayers.Layer.WMS.
> If you need other types, you could look at the OWS Context specification
> by OGC, but there is no OL code currently for this format. Mapbuilder
> does have code for this IIRC.
> Best regards,
> Bart
> Burgholzer,Robert wrote:
>> I am interested in developing a parser that would take a block of XML
>> describing a map view (maybe SLD notation?) and turn it into
>> OpenLayers javascript code.  Once I have done this, I would like to
>> turn it into a WordPress plugin, so that maps can be dynamically added
>> to blogs, real, custom maps that is.  The things I think I need to
>> know before starting this are:
>>    1. Is there already something out there that does this?
>>    2. What format is considered the best standard, SLD, or some other?
>>    3. Is this interesting to others as well?
>> Thanks!
>> Robert W. Burgholzer
>> Surface Water Modeler
>> Office of Water Supply and Planning
>> Virginia Department of Environmental Quality
>> rwburgholzer at deq.virginia.gov <mailto:rwburgholzer at deq.virginia.gov>
>> 804-698-4405
>> Open Source Modeling Tools:
>> http://sourceforge.net/projects/npsource/
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Dev mailing list
