[OpenLayers-Dev] help with unregistring Layer.Text "markerClick"
event
Julio RENELLA
julio.renella at exyzt.fr
Thu Apr 23 12:44:13 EDT 2009
Hi everybody !
Please, can someone help me to find a solution (if possible) for this
problem :
At this time, I have a map with only one event (the mouse-click) in
order to produce
a popup info of a place (thanks to the coordinates I pick through the
mouse-click event).
Now I need to insert a TEXT layer (maybe many of you doesn't use it
since long time)
with it's own markers.
The problem is that I would like to keep my first event (mouse-click)
over the "markerClick"
event of the Text layer... Better, I would like to unregister (or
forbid) this "markerClick" event.
Do you think it's possible to do such a thing ?
Or maybe it can't be done beaucause the Text layer wasn't made for this
kind of use... ?
An alternative can be replacing the Text layer by a GML layer. This way
I don't disrupt
the event that I need... But only in the case that my problem do not
have solution !
Can someone help me with an advice ?
Thanks !!!
More information about the Dev
