[OpenLayers-Dev] [OpenLayers-Users] Error when using
XMLHTTPRequest (throughrefreshing a wfs layer every n seconds)
Christopher Schmidt
crschmidt at metacarta.com
Wed Apr 29 08:16:45 EDT 2009
On Wed, Apr 29, 2009 at 11:25:57AM +1000, Roald de Wit wrote:
> Christopher Schmidt wrote:
> >Kris,
> >Thanks for the work on this. Two things:
> > * Since the XMLHttpRequest code is, as I understand it, primarily taken
> > from the XMLHttpRequest project (that you linked); are the changes
> > that you put in that file already included in1.0.3 of XMLHttpRequest?
> > (Unfortunately, the license for that library changed, so now I have
> > to go read the LGPL and figure out if we can just pull the latest
> > version from them.)
> The license for XMLHttpRequest.js is LGPLv3 and therefore most probably
> too restrictive (IANAL). The schema on the following page [1] says: you
> can use BSD-new with LGPLv3 but then your project falls under the latter
> license.
> Maybe it's an idea to contact the author of XMLHttpRequest.js and ask
> him to release under a more permissive license (as well)? He might not
> realise the problems his new license is causing us (and probably more
> projects).
I doubt it. He originally made it Apache, then switched to LGPL, as I
understand it -- which speaks of a decision being made to make that
change, which means that he'd be unlikely to want to switch back.
-- Chris
> Regards,
> Roald
> [1] http://www.dwheeler.com/essays/floss-license-slide.html
> Roald de Wit
> Software Engineer
> roald.dewit at lisasoft.com
> Commercial Support for Open Source GIS Software
> http://lisasoft.com/LISAsoft/SupportedProducts/
> The contents of this email are confidential and may be subject to legal or
> professional privilege and copyright. No representation is made that this
> email is free of viruses or other defects. If you have received this
> communication in error, you may not copy or distribute any part of it or
> otherwise disclose its contents to anyone. Please advise the sender of your
> incorrect receipt of this correspondence.
Christopher Schmidt
MetaCarta
More information about the Dev
