[OpenLayers-Dev] text labels in IE8
Christopher Schmidt crschmidt at metacarta.com
Mon May 4 12:41:23 EDT 2009
On Mon, May 04, 2009 at 11:20:18AM -0400, Mike Adair wrote:
> Yes, I'm testing against trunk (and also the OL2.8 branch).  When I was
> doing these tests, the compressed file coming from openlayers/dev/ had a
> revision tag of 9309 in it, which is just before the 2.8 RC1 release I
> believe.
> Testing again this morning I found that when the example is served from
> my local MS4W Apache, it is working correctly, but served from a local
> Oracle Application Server instance the labels are placed incorrectly.
> I'll investigate that further.
Possibly a different doctype is being placed on the doc wrapped in
Oracle.
> Mike
> Christopher Schmidt wrote:
> >On Mon, May 04, 2009 at 10:19:01AM -0400, Julien-Samuel Lacroix wrote:
> >>It would help to know where the files are coming from.
> >>Is the compressed file on openlayers.org [1] built from SVN or from a
> >>release?
> >That is built from SVN every time a new checkin is made.
> >>Do you use trunk or a sandbox?
> >Since he's said he's using /dev/, he's using trunk.
> >-- Chris
> >>Julien
> >>[1] http://openlayers.org/dev/OpenLayers.js
> >>Mike Adair wrote:
> >>>So I've been banging my head on IE for long enough on this, I'd like to
> >>>know if anyone else has any ideas...
> >>>I'm trying to get the new vector labeling working in IE8 and to figure
> >>>out why it's not working locally.  All test cases are in IE8
> >>>compatibility mode, Quirks mode.
> >>>If I go to the examples page at:
> >>>http://openlayers.org/dev/examples/vector-features-with-text.html  it
> >>>works without a problem, labels show up aligned with the vector features.
> >>>If I load the example served from my local machine (from an MS4W
> >>>instance), the labels all appear in the top-left corner. (both default
> >>>single-file build and loading individual files)
> >>>If I load the example served from my local machine  but with the
> >>>OpenLayers single file build at http://openlayers.org/dev/OpenLayers.js
> >>>it works properly.
> >>>Doing a diff on the generated VML shows that for the one that works, the
> >>><ovl:textbox> node has extra style properties of:
> >>>"MARGIN-TOP: 88.875pt; MARGIN-LEFT: 141.375pt; TOP: auto; LEFT: auto"
> >>>which appears to make the labels show up in the correct place.  I've
> >>>searched the WML renderer code and I can't find anywhere that is adding
> >>>those properties
> >>>So I guess the questions are:
> >>>- what's the difference between a local single file build and the one
> >>>server from openlayer.org?
> >>>- anyone know what is adding those extra style properties?
> >>>Thanks for any pointers,
> >>>Mike
> >>Mapgears
> >>http://www.mapgears.com/
> >>_______________________________________________
> >>Dev mailing list
> >>Dev at openlayers.org
> >>http://openlayers.org/mailman/listinfo/dev
>   Michael Adair
>   Senior Software Architect
>   DM Solutions Group Inc.
>   Office: (613) 565-5056 x26
>   madair at dmsolutions.ca
>   http://www.dmsolutions.ca
>   http://research.dmsolutions.ca
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
