[OpenLayers-Dev] feature.bounds versus feature.geometry.bounds
Tim Schaub
tschaub at opengeo.org
Thu Nov 12 21:13:06 EST 2009
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> this discussion came up again in ticket 2255
> (http://trac.openlayers.org/ticket/2255). I know it has come up before
> (but I cannot find the respective thread right now).
> What is our policy with respect to setting feature.bounds or
> feature.geometry.bounds with values from server-side retrieved formats?
> The current state of affairs in OpenLayers is:
> -GeoJSON: sets the bounds to feature.bounds
> -GML.Base sets the boundedBy info to feature.geometry.bounds
> In my opinion it would be good to get one rule adopted for all formats,
> and for me the most logical thing is setting feature.bounds. I see two
> reasons for this:
I don't think we need the same rule for all formats. But...
> 1) in GML the boundedBy property conceptually maps to the feature and
> not the geometry
yes, in GML this is the feature bounds. So you are correct, it should
map to feature.bounds in OL.
In GeoJSON, any object can have a bounds member. When present on the
geometry, it should be set on the geometry by the parser. When present
on a feature, it should be set on the feature by the parser.
We don't parse the bounds member on GeoJSON geometries. I don't think
this is a problem, but it could be patched.
I also don't think we should say feature bounds is from the server and
geometry bounds is calculated on the client. (And I'm correcting myself
if I've said otherwise before.) A feature could have multiple
geometries. We use geometry.bounds frequently. If people are really
relying on feature.bounds, it should be updated when any geometry bounds
change (and we should have a getter instead).
Tim
> 2) as you can see in the patch for ticket 2255, GML can have a boundedBy
> property but have no geometry included in the feature
> Tim, can you recall why you wanted it to map to feature.geometry.bounds
> in GML.Base?
It was a mistake. See the updated patch.
http://trac.openlayers.org/ticket/2255#comment:5
Tim
> Best regards,
> Bart
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
