[OpenLayers-Dev] OpenLayers 3.0 IRC Meeting summary
christopher.schmidt at nokia.com
Sun Jul 4 09:42:38 EDT 2010
On Jul 4, 2010, at 4:55 AM, ext Peter Robins wrote:
> On 24 June 2010 18:29, Bart van den Eijnden <bartvde at osgis.nl> wrote:
>> 2) Streamlining the drag flow
>> 7) Things which are called many times (which we now know/can examine) should be improved performance wise
> this is the same issue, no? 2) belongs in with 7)
2 is an (important) subset of 7; if we did not improve any other
'hot' codepaths, we would most certainly want to make sure that
we took care of #2, because it's the one that most users are
likely to run into. There may be other things that have similar
behavior, but that's the most important one.
Regards,
Christopher Schmidt
Nokia
More information about the Dev
