[OpenLayers-Dev] OpenLayers 2.9.1 released
bartvde at osgis.nl
bartvde at osgis.nl
Thu May 6 09:35:01 EDT 2010
The OpenLayers Development Team is proud to announce the release of
OpenLayers 2.9.1, the first bug fix release of OpenLayers 2.9.
Since the 2.9 release 3 regressions have been fixed, as well as 2
documentation errors:
* Protocol.HTTP: PUT and DELETE should use url from options (#2393)
* do not use getDimensions anymore, but use offsetWidth and offsetHeight
(#2414)
* Rotated graphics are positioned incorrectly when moved or zoom changes
(#2596)
* preload default value is incorrect in Strategy.Fixed documentation (#2611)
* isBaseLayer default value is incorrect in Layer.Vector documentation
(#2613)
See also: http://trac.openlayers.org/wiki/Release/2.9.1/Notes
For information on possible changes that will need to be made between
this version of !OpenLayers and previous versions, please look at the
Release notes, available at the Release Notes information [1].
[1] http://trac.openlayers.org/wiki/Release/2.9.1/Notes#CompatibilityNotes
Best regards,
Bart
More information about the Dev
