[OpenLayers-Dev] Harware accelerated CSS3 animations for iOS
Gregers Gram Rygg
gregersrygg at gmail.com
Tue Apr 12 16:59:39 EDT 2011
On Tue, Apr 12, 2011 at 5:54 PM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> Right now pinchzoom isn't supported for the commercial layers. The
> commercial layers aren't in the "layer container" div, which the div
> we scale and translate on pinch. So targetting Tile.Image sounds good
> to me at this point. And for now I think it'd great to document this
> trick in the "mobile" section of our narrative doc. Would you provide
> a patch for that?
Sure, but I'm not sure which documentation you're referring to. This one?
http://docs.openlayers.org/library/mobile.html
Can't find the page in svn or a way to edit the page.
Should I also submit a patch for style.css (ver 2.12)?
> Also, have you tried applying the translate3d hack directly to the
> layer container div? (Sorry if it isn't relevant.)
Yes, but I was unsuccessful.
Gregers
More information about the Dev
