[OpenLayers-Dev] trac login error 500
Bruno Binet bruno.binet at camptocamp.com
Tue May 3 02:21:29 EDT 2011
Thanks, I confirm that this issue is now fixed.
On 3 May 2011 01:13, Tim Schaub <tschaub at opengeo.org> wrote:
> Looks like they've fixed up the SSL certificate issue.
> See http://lists.osgeo.org/pipermail/discuss/2011-May/008869.html for more
> detail.
> Tim
> On 5/2/11 2:17 PM, Tim Schaub wrote:
>> This is an OSGeo-wide issue.
>> http://logs.qgis.org/osgeo/%23osgeo.2011-05-02.log
>> On 5/2/11 10:53 AM, Bruno Binet wrote:
>>> Hi,
>>> I've just tried to login with my openlayers trac account, but
>>> http://trac.osgeo.org/openlayers/login url leads to a 500 Internal
>>> Server Error.
>>> Does someone with access to the server could check the logs and
>>> hopefully fix this error?
>>> Thanks,
>>> Bruno
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Bruno Binet
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Mail : bruno.binet at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
