[OpenLayers-Dev] using wrapDataLine in Markers layer
ron
thorsonr at saic.com
Tue Jul 17 09:19:33 PDT 2012
I am relatively new to using OpenLayers with GeoServer map server. The
customer for which the application is developed for requires the opening map
to be located in the central Pacific region. I am using shape files with
wrapDateLine set to true for the basemap, which works as expected
(displaying from Chine to weatern US).
The problem I am encountering is in my Markers layers ( I have 5 layers
showing earthquake symbols and bouy symbols). The only symbols which appear
are on the side of the date line of the map center position,i.e. if map
center is 35.9-174.0 then no symbols appear on the western hemisphere. The
following code creates the map layer:
var buoys = new OpenLayers.Layer.Markers( "Deployed Buoy" ,
{displayOutsideMaxExtent: true,wrapDateLine: true});
I tries without the max extent option with no difference.
Is this a code problem or an OpenLayers issue?
Thanks for any help.
Aloha.
View this message in context: http://osgeo-org.1560.n6.nabble.com/using-wrapDataLine-in-Markers-layer-tp4988854.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
