[OpenLayers-Dev] using wrapDataLine in Markers layer
Phil Scadden
p.scadden at gns.cri.nz
Tue Jul 17 14:14:34 PDT 2012
| Is this a code problem or an OpenLayers issue?
The dateline is major pain in the butt. With your combination, I would say firstly, make sure you are using OL 2.12 and Geoserver 2.1.2. Geoserver data should always be tiled with a tiling scheme that breaks on the 180. (We use 900912 so can overlay with google maps and that works fine). Living in NZ, its a nightmare that just goes on and on. At least geoserver and OL make a decent effort though there are still hoops to go through.
I have never used a marker layer - always stuck to server layers. Some particular reason for using markers? You may have to use firebug to work through what OL is doing to the coordinates.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
More information about the Dev
