[OpenLayers-Dev] using wrapDataLine in Markers layer
ron
thorsonr at saic.com
Wed Jul 18 07:04:42 PDT 2012
(1) I believe this is a code issue...although it could be dateline is not
supported in the markers layer
(2) I am using OL 2.11 and GeoServer 2.1.4
(3) I selected the markers layer object basiclly because it was the easiest
to use. I have only map points and event popups on each marker.
View this message in context: http://osgeo-org.1560.n6.nabble.com/using-wrapDataLine-in-Markers-layer-tp4988854p4989095.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
