[OpenLayers-Dev] SelectFeature outFeature method
Xavier Mamano (jorix) xavier.mamano at gmail.com
Wed Jul 18 09:55:52 PDT 2012
Thank you very much (to me is hard to remember without touching the code)
I understood everything :-)
In my case the problem was masked because a select popup closes any popup.
Maybe you may be interested see where I have applied this:
https://github.com/jorix/OL-FeaturePopups
Xavier
scottseeker wrote
> I'm not at work at the moment, but I believe I remember the case and will
> give as much details as I can.
> I have two select controls.
> - a popup control which triggers the featurehighlighted and
> featureunhighlighted events (highlightOnly=true & hover=true)
> - a multi-select control (multiSelect=shiftKey, hover=false).
> The case for the second added line happened when I would hover over a
> feature (this is a point feature), which would show the pop-up and then
> select the point by clicking on it.  I would then move my mouse away which
> would cause the pop-up to disappear and the point to remain selected as I
> intended.  But, when moving the mouse over the point again the pop-up
> would appear, but would not disappear on mouse-out.  This was the cause
> for the second call to featureunhighlighted.
> This does seem to trigger some unnecessary calls to
> 'featureunhighlighted', all I'm doing in the function is deleting the
> pop-up so it hasn't been an issue for me.
> There also seems to be a case where the popup remains if I move the mouse
> fast enough (before I made the change this problem existed), it doesn't
> happen often so hard to pinpoint exactly what I'm doing that causes it.
> (Apologize for the 20 edits, preview msg was failing for me?)
View this message in context: http://osgeo-org.1560.n6.nabble.com/SelectFeature-outFeature-method-tp3890333p4989132.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
