[OpenLayers-Dev] Re: WFS/Vector + Cluster + SelectFeature = bug?
Jesse V. Griffis
jesse.griffis at nbtsolutions.com
Fri May 4 07:31:17 EDT 2012
Hi Xavier,
This is very cool, and appears to work really well. I will integrate it into
my application and see how it works on a larger scale.
When you say it isn't finished, are there more features you are planning to
add, or are there bugs I should be wary of?
I also see it's in the OpenLayers namespace and the copyrights and such are
all there - is this something that may be integrated into the core at some
point?
Thanks much,
Jesse
On Thursday, May 03, 2012 10:43:26 AM Xavier Mamano wrote:
> Hi Jesse,
> Currently this scenario is adverse: BBOX and Cluster! :(
> I have been developing a tool to be able to face it. It is not finished but
> can comfortably handle this scenario.
> View your example rewritten using FeaturePoups:
> http://jorix.github.com/OL-FeaturePopups/examples/nbtsolutions-FP.html is
> simpler.
> NOTE: I used HTTP instead WFS protocol in order to show the example on
> GitHub Pages.
> Feedbacks are welcome.
> Regards,
> Xavier Mamano
> Jesse V. Griffis wrote
> > Greetings,
> > Here's the situation:
> > 1. Copied basic map setup from popup demo here:
> > http://openlayers.org/dev/examples/select-feature-openpopup.html
> > 2. Modified to include the general WMS world map, plus a sample WFS layer
> > I am
> > working with.
> > 3. WFS layer includes BBOX + Cluster strategies.
> > 4. Included only the SelectFeature control and activated on init. No other
> > special stuff.
> > Here's the URL, js self-contained:
> > http://icf.nbtsolutions.net/test/
> > To reproduce my issue:
> > 1. Click any of the vector features. See the popup.
> > 2. Click zoom in on the zoom bar.
> > 3. Try to close the popup with the red X.
> > 4. See the 'layer is null' broken js in firebug.
> > It's coming from SelectFeature.unhighlight, line 483 (git clone'd a couple
> > weeks ago).
> > If you remove the Cluster strategy, the bug goes away.
> > Should I report this as a bug, or send this note to the -users list to
> > figure
> > out how to do it correctly? :-)
> > Thanks,
> > Jesse
> > Jesse V Griffis
> > Senior Developer
> > NBT Solutions LLC
> > Buffalo, NY
> > phone: 716.210.6092
> > email: jesse.griffis@
> > web: www.nbtsolutions.com
> > Dev mailing list
> > Dev at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> http://osgeo-org.1560.n6.nabble.com/WFS-Vector-Cluster-SelectFeature-bug-tp
> 4947562p4950040.html Sent from the OpenLayers Dev mailing list archive at
> Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
Jesse V Griffis
Senior Developer
NBT Solutions LLC
Buffalo, NY
phone: 716.210.6092
email: jesse.griffis at nbtsolutions.com
More information about the Dev
