[OpenLayers-Dev] Parsing WFS Filter Capabilities
sredl at ccss.cz sredl at ccss.cz
Wed May 16 11:15:38 EDT 2012
Dear all,
WFS Capabilities document contains <ogc:Filter_Capabilities> section,
which is not parsed in the OpenLayers at all. To work with WFS Filters
reasonably, we need to parse it.
In the
http://trac.osgeo.org/openlayers/ticket/3652
I have attached a patch that solves the basics. It introduces different
namespaces in the WFS Capabilities parsing and parses everything what is
needed for Comparison filters. (Stuff for other filter types, such as
<ogc:Spatial_Capabilities> is not parsed yet.) DescribeFeatureType URL
is also covered in the patch. WFS 1.0.0 and WFS 1.1.0 is covered.
Hope some of you will find it useful.
Kind Regards,
Michal
P.S. I have also attached the patch in a different form - instead of
modifying the current code, we have extended it in a set of independent
definitions - this is how we currently use it before the patch is
applied. So just in case someone would like to do the same .
More information about the Dev mailing list
