[OpenLayers-Dev] [Polygon Rendering] Inverse fill
Eric Lemoine
eric.lemoine at camptocamp.com
Sun May 20 17:45:04 EDT 2012
On Sunday, May 20, 2012, RICHARD Didier wrote:
> >> Ok, so the workaround (VML, Canvas) cannot be considered as a good
> >>> solution : better cut the geometry and keep VML, SVG, Canvas order.
> >> Fixing the SVG geometry clipping code would be the best solution. Don't
> >> know how difficult it would be though.
> > Yeap cause the bug appears under Chrome/Windows, Chromium/Linux and IE9!
> > (I didn't check yet under IE8)
> More tests and hints :
> IE8/WXP: working
IE 8 does not support SVG, so the VML is selected by OpenLayers for vector
rendering.
> Chromium 18/Linux: working (when VML, Canvas, not with default renderers)
In that case the Canvas renderer is selected.
> Chrome 18 et 19/WXP : working (when VML, Canvas not with default renderers)
> IE9/W7: working in IE8 mode, not in IE9 mode
Indeed. IE 9 supports SVG while IE 8 does not.
This makes it clear that the bug is in OpenLayers' SVG renderer, and that
the Canvas and VML renderers work correctly.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120520/a0b233f2/attachment.html
More information about the Dev
