[OpenLayers-Trac] [OpenLayers] #3373: Handler.RegularPolygon: Error
JS using documentDrag=true.
trac-20090302 at openlayers.org
Sun Jun 19 07:02:37 EDT 2011
#3373: Handler.RegularPolygon: Error JS using documentDrag=true.
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.RegularPolygon | Version: 2.11 RC1
Keywords: | State:
Dragging the vertex of the polygon out the map (when documentDrag=true)
appears an JS error and drag does not work out the map. Then if you
release the mouse out the map when you enter in the map continues draging
(without pressing the mouse)
This problem is more important if the patch #3363 is applied.
Ticket URL: <http://trac.openlayers.org/ticket/3373>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
