[OpenLayers-Users] single file library distorts size of markers?
Erik Uzureau erik.uzureau at metacarta.com
Wed Aug 8 10:24:37 EDT 2007
Joanne,
In the 2.4 uncompressed link you send, I am able to see the markers
when I zoom in (although they are displayed as vector data).
I checked out the two different versions of 2.3 and they are indeed
different, though It seems very bizarre to me that this would be
happening only because of the js minimizer.
Have you tried running your page with the latest from trunk? It would
be good to see if this problem is still happenning there. We'll be
making a 2.5 release sometime in the next month and it will be good to
track this down.
Unfortunately, I am not the most up-to-date on the WFS code. Maybe
someone who has been working on that section of the project could help
you out more.
I've created this ticket if someone else wants to take a look at it:
http://trac.openlayers.org/ticket/896
Thanks for the detailed report.
Erik
On 8/8/07, Joanne Cook <j.cook at oxfordarch.co.uk> wrote:
> Hi List,
> I am experimenting with the compressed single file version of OpenLayers and have come across a couple of issues with the size of the markers I use for wfs. I'm sure there's a simple reason for it but I can't figure it out.
> I have replaced the default marker (/img/marker.png) with a custom one, and when I use the compressed library it makes the marker much larger. To see this behaviour in the examples below, please zoom in far enough to swap from wms to wfs- it's quite clear when the markers change.
> http://mapdata.thehumanjourney.net/index_nocomp_gs.html uses the non-compressed library (OL2.3)
> http://mapdata.thehumanjourney.net/index_comp_gs.html uses the compressed library (OL2.3)
> The only difference between the two is that the non compressed version uses the /lib/OpenLayers.js and the compressed one uses OpenLayers.js.
> Furthermore, when I try this with OpenLayers2.4, I have an even more confusing problem, in that the compressed version displays the same problem as with 2.3, whereas the non-compressed version seems to lose the marker altogether.
> http://mapdata.thehumanjourney.net/index_nocomp_gs_24.html is the non-compressed version using OL2.4.
> Any thoughts?
> Many thanks
> Jo
> Joanne Cook
> Information Systems Coordinator
> Oxford Archaeology (North)
> 01524 541000
> http://thehumanjourney.net
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://openarchaeology.net/iso26300 for more information.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
