[OpenLayers-Users] Markers and Vector-Features displaced after
mouse-dragging
Zimmermann, Tobias
Tobias.Zimmermann at iml.fraunhofer.de
Wed Aug 22 04:35:43 EDT 2007
Hi again!
I'm trying to do some guesswork on this behaviour:
- Since the markers stay correct with a Google-Maps-Base-Layer I assume
that OpenLayers uses the GoogleMaps-API function to display them...
- This is documented somewhere and I haven't found it yet...
- I have not initialized the Base-Layer in the right way...
- You would like to see some examples.
- OpenLayers does some rounding-errors while calculating the new
positions (which would puzzle me because the vector-example seems to
display them really fixed at their positions).
Btw: The same thing happens when zooming is done on the map.
It would be really nice if someone could tell me about the reliability
of Vector-Features. I'm trying to display routing-results which should
match to the underlying map-routes. If OpenLayers is not able to display
them correctly I would be in less trouble since I have an explanation ;)
Thanks,
Tobias
> Hi there!
> I'm trying to display some Vector-Features (LineStrings) with Markers
at their endpoints.
> My base-layer is requested from my own MapServer using an
Untiled-Layer. My OpenLayers-Version is 2.4
> (the downloadable stable Version).
> After initializing the map looks fine but after dragging the map lines
and markers are displaced a little bit.
> Changing the Base-Layer to Google-Maps let the markers stay at their
intended position but shifts the vector-features.
> The only base-layer which does not seem to show displaced features and
markers is the one I found on the examples page.
> Has someone seen this behaviour before?
> Kind regards and many thanks in advance,
> Tobias Zimmermann
