[OpenLayers-Users] Exception Error
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Mon Dec 3 09:18:21 EST 2007
Did you check if Python is available on your server machine? Just try
python in a shell.
Is your server able to connect to remote services? Does it need proxy
settings etc. to connect to outside services? Did you check your Apache
error log?
For your javascript you should use:
OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url="
Best regards,
Bart
R. Ortner schreef:
> ok,
> i put > OpenLayers.ProxyHost =
> "/cgi-bin/proxy.cgi?url=http://172.xx.xx.xx/cgi-bin/proxy.cgi"; < into my
> script. This maybe works but i get again (now within my application the
> internal server error "unhandled request return server error").
> could there be a problem with the accessibility of the cgi-bin directory? it
> is set to chmod 755
> (i get the same internal server error when i call the proxy.cgi directly in
> the browser?)
> Bart van den Eijnden (OSGIS)-2 wrote:
>> You need to define OpenLayers.ProxyHost in your javascript code, not in
>> your Apache config file.
>> Best regards,
>> Bart
>> R. Ortner schreef:
>>> need some configuration help please!
>>> i copied the proxy.cgi in my cgi-bin dir. and put the
>>> < OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url="; >
>>> into my httpd.conf from my appache webserver.
>>> (the url= is the url which i like to call with my applicatoin (e.g.
>>> http://gis.at/com.esri.wms.Esrimap/geoland2), i guess or the url to the
>>> proxy.cgi? (e.g. http://172.xx.xx.xx/cgi-bin/proxy.cgi))
>>> when i now restart the appache webserver i get the following message:
>>> Invalid command 'OpenLayers.ProxyHost', perhaps mis-spelled or
>>> defined
>>> by a module not included in the server configuration
>>> when i trie to call the proxy.cgi with
>>> http://172.xx.xx.xx/cgi-bin/proxy.cgi:
>>> Internal Server Error
>>> The server encountered an internal error or misconfiguration and
>>> was
>>> unable to complete your request.
>>> Please contact the server administrator, [no address given] and
>>> inform them of the time the error
>>> occurred, and anything you might have done that may have caused
>>> the
>>> error.
>>> More information about this error may be available in the server
>>> error
>>> log.
>>> Christopher Schmidt-4 wrote:
>>>> On Mon, Dec 03, 2007 at 04:31:59AM -0800, R. Ortner wrote:
>>>>> Any idea whats wrong?
>>>> http://en.wikipedia.org/wiki/Same_origin_policy
>>>> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#WhydoIneedaProxyHost
>>>> Regards,
>>>> Christopher Schmidt
>>>> MetaCarta
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>> OSGIS, Open Source GIS
>> bartvde at osgis.nl
>> http://www.osgis.nl
>> Users mailing list
bartvde at osgis.nl
http://www.osgis.nl
