[OpenLayers-Users] WFS layer does not overlay with the WMS layer in Mozilla FF
oven38 oven38 at volja.net
Mon Dec 10 19:56:31 EST 2007
Do you use GeoServer ?
GeoServer has proprems to transform  from and to some SRS's with BBOX
parameter in WFS GetFeature requests.
lp, Alfred
> I have the same problem. I was displaying a client-side vector layer over a
> GoogleMaps base which did not align. However, when I changed to a base that
> had been tiled in "EPSG:4326" the problem goes away - i.e. in both IE and FF
> the vectors align. I just assumed it was a projection issue with the
> Google/Yahoo/Multimap bases that would be solved with the
> "sphericalMercator: true" option being set to the Vector layer. However,
> this did not work and why does it align in IE and not in FF anyway?
> If someone wants me to produce a demonstrator of this I can.
> Cheers,
> Brad......
