[OpenLayers-Users] WFS layer does not overlay with the
WMS layer in Mozilla FF
bradleyspencer
brad at cubewerx.com.au
Mon Dec 10 20:02:32 EST 2007
No, I am using CubeWerx for my WMS. This returns geometry in a
GetFeatureInfo request quite OK. This is very much a browser dependent issue
(I think) as it works fine in IE 7 but is offset in FF.
It is very weird.
Chewers,
Brad Spencer
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]On
Behalf Of oven38
Sent: Tuesday, 11 December 2007 11:57 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] WFS layer does not overlay with the WMS layer in
Mozilla FF
Do you use GeoServer ?
GeoServer has proprems to transform from and to some SRS's with BBOX
parameter in WFS GetFeature requests.
lp, Alfred
> I have the same problem. I was displaying a client-side vector layer over
a
> GoogleMaps base which did not align. However, when I changed to a base
that
> had been tiled in "EPSG:4326" the problem goes away - i.e. in both IE and
FF
> the vectors align. I just assumed it was a projection issue with the
> Google/Yahoo/Multimap bases that would be solved with the
> "sphericalMercator: true" option being set to the Vector layer. However,
> this did not work and why does it align in IE and not in FF anyway?
> If someone wants me to produce a demonstrator of this I can.
> Cheers,
> Brad......
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
