[OpenLayers-Users] problems with the overview map
Lars Schrader
lars.schrader at web.de
Thu Feb 15 09:53:59 EST 2007
Hello Tim,
thanks for your email. I think the missing 'mapOptions'-phrase was one reason
for my problem. Today I have solved the problem. The solution was your
suggestion and the idea from Bart. Thanks a lot!
One another problem: Is at right, that the layer for the overview map must be
a base layer?
Greetings, Lars
Am Mittwoch, 14. Februar 2007 18:25 schrieb Tim Schaub:
> Lars Schrader wrote:
> > What I want to have is a OverviewMap, which always shows the complete
> > area of interest (the complete WMS-Layer). No Zoom-In and no Zoom-Out.
> > Only the red rectangle should change his position.
> The numZoomLevels has to be set on the mapOptions property of the
> control's options.
> var options = {mapOptions: {numZoomLevels: 1}};
> map.addControl(new OpenLayers.Control.OverviewMap(options));
> This is also true of any other options that you want to set on the
> overview map control's map. For example, instead of setting maxExtent
> as a property of the control, it needs to be set as a property of the
> control's map - this is done with the mapOptions property of the control.
> This is a bit confusing without looking at an example. Take a look at
> the examples on the wiki page
> (http://trac.openlayers.org/wiki/Control/OverviewMap#Customprojectionsexten
>tsetc.)
> Write back if you still have trouble.
> Tim
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
