[OpenLayers-Users] when panning E/W, map shifts in Y direction
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Feb 16 09:58:35 EST 2007
Sorry meant 2.3RC2 ofcourse.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Naar: users at openlayers.org <users at openlayers.org>
Onderwerp: [OpenLayers-Users] when panning E/W, map shifts in Y direction
Datum: 16/02/07 12:57
> Hi list,
> just got a report of the following (using 2.2RC2):
> if the map is panned, for instance 4 times to the right using
> map.pan(map.size.w/2, 0), and then back again 4 times
> (map.pan(-map.size.w/2, 0), the map
> shifts in the Y direction.
> Does anybody have an idea what could cause this?
> The bbox's in the url's are:
> 1) initial situation:
> 111358.132624,403032.302298,118389.382624,408101.342995
> 2) after panning 4 times to the right:
> 125420.632624,403082.615357,132451.882624,408151.656054
> 3) after panning 4 times back to the initial location:
> 111358.132624,403132.928416,118389.382624,408201.969113
> As you can see the shift is 100 meters in the Y direction.
> Best regards,
> Bart
> http://www.osgis.nl
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
