[OpenLayers-Users] Problems with Safari Recently with the
latest build...
Lance Dyas
lancelot at inetnebr.com
Mon Jan 22 01:16:54 EST 2007
sorry about the vagueness I am at home now.. .(I'm not set up for
debugging easily on my mac here)
but an example is at
http://www.microimages.com/ogc/maps/nebraskaopen.htm
Christopher Schmidt wrote:
> On Sun, Jan 21, 2007 at 09:49:20PM -0600, Lance Dyas wrote:
>> I had a problem with pages failing entirely to load when a non existant
>> Dom object... a filter for IE specific handling
>> was having its value set .... does anyone out there test with MacOS10.4
>> and Safari.
> All releases are tested in development mode before release on OS X. I'm
> currently able to load the files in the dev/examples/ dir with no
> problem: specifically, I started at
> http://openlayers.org/dev/examples/controls.html and explored a couple
> others and had no problem.
> Can you be more specific about what your problem is, and if you can
> reproduce it on that file or any other file hosted in the /dev/examples/
> directory?
> Regards,
