[OpenLayers-Users] Regarding setup of wfs layers in opelayers.
Christopher Schmidt
crschmidt at metacarta.com
Wed Mar 14 10:05:32 EDT 2007
On Wed, Mar 14, 2007 at 07:01:28AM -0400, Schuyler Erle wrote:
> On Tue, 2007-03-13 at 11:14 +0530, Kanhaiya kale ( ????????????????????? ???????????? ) wrote:
> > Hi all,
> > I am using openlayers. i have setup wms layers using mapserver and
> > geoserver. Now, i want to setup wfs layers using geoserver.
> > wms layers with geoserver is working properly but wfs layers from
> > geoserver is not getting displayed in openlayers. i tried examples of
> > openlayers but it is not of help.
> > Source code of given my example is http://rafb.net/p/INgwb641.html .
> > I googled for this problem. I tried source code of 3-4 wfs examples.
> > example's layers are working on localhost but not of mine. It is not
> > showing errors. but layer is also not getting displayed. There is also
> > no javascript error.
> Unfortunately your example's not available any more, apparently, but
> have you considered cross-browser security issues? If your geoserver is
^^ cross-domain
> on a different host or port from the one you're serving OL from (which
> seems likely), then the browser may silently refuse to load anything
> from it.
Note that the 'silently' is actually due to OpenLayers catching and
silently throwing away the exception. But yes.
KK: You need to set up a ProxyHost. I know you had one working at one
point, but your example that you pasted no longer had it. Once you get
the ProxyHost back in place, let us know what happens.
Regards,
Christopher Schmidt
MetaCarta
