[OpenLayers-Users] Moving in map WMS/GML
Dipl.-Inf.(FH) Carsten Eider
eider at fh-bingen.de
Fri Mar 16 06:24:00 EDT 2007
Hi folks,
there is a strange behaviour in my map, where i use
normal LAYER.WMS.UNTILED and two LAYER.GML(EPSG:31467)
1.) When I grab the map and move to any direction,
the underlying wms.layers are move correctly, but the gml.layers are
move the double way.
(See attachment after.png=moveWest(before.png)
If I zoom out and in again, the display is corrected.
2.) We restrict the displayable area with a maxExtent.
If i use a much more larger maxExtent than the area i want to see,
the area is not the one i want to see. I even cannot move to the area I
should normally be
map = new OpenLayers.Map($('map'), {
projection: "EPSG:31467",
maxExtent: maxEBBOX,
maxResolution: "auto",
units: 'meters'
Unfortunately I don't remember which trunk/branch of openlayers i am using.
What is the actual trunk for using wms und gml.layers ?
Any suggestions for my errors?
thx carsten
Mit freundlichen Grüßen / Yours faithfully
Carsten Eider
Dipl. Inf. (FH)
Kompetenzzentrum für Innovative Informationssysteme
c/o Fachhochschhule Bingen / University of applied sciences Bingen
Berlinstraße 109
55411 Bingen
Tel: +49 (0) 6721 / 409-179
Fax: +49 (0) 6721 / 409-158
email: eider at fh-bingen.de
Internet: iis.fh-bingen.de
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070316/04bafc1b/after.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070316/04bafc1b/before.png
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070316/04bafc1b/eider.vcf
