[OpenLayers-Users] GML features not lining up in FireFox
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Fri May 18 09:07:08 EDT 2007
Obe, Regina wrote:
> I have a map that displays a Mapserver WMS of Abandoned property points
> and when the user clicks on a red dot, it queries the WFS service to get
> the detail of that section and overlays the WFS points as an extra layer.
> In IE 7, my WMS and WFS line up perfectly, but in Firefox, the WFS seems
> a bit skewed off the mark.  Am I doing something wrong or is this a
> known issue.
> I'm using the OpenLayers version in CVS.
> Below is the link to my map.
> http://www.cityofboston.gov/dnd/AbandonedPrivateMap.aspx
> Thanks,
> Regina
Your dots are off in firefox directly proportional to the distance
north/south of the center of the map image. The farther you are from the
centerline the farther off the point is from the correct place.
Don't know if this helps, but it is a pattern the might hint as to what
is happening.
-Steve
