[OpenLayers-Users] How to solve XMLHTTPREquest problem on IIS??
Christopher Schmidt crschmidt at metacarta.com
Thu Nov 15 06:48:37 EST 2007
On Thu, Nov 15, 2007 at 02:22:36AM -0800, springrider wrote:
> Good morning
> I thought everything was OK with my js code and my WFS request for
> extracting the bounds of my features until i start playing with different
> URLs. It seems i can not retrieve information from remote domains. I check
> the forums and each time, the solution is given for Apache Users... In my
> organization we are IIS customers.
> Could anyone give me some indications about how set up a proxyhost for an
> IIS server?
The clientside setup matches the setup for Apache. However, there have
been reports that the existing proxy.cgi don't work under IIS (though it
should). It would require Python and setting up Python CGI support, and
you could use the client side setup described in
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
> If i use a GeoJson output format, do i evade the problem? Not sure because
> it remains a WFS request, no??.
Yes, you still have a problem.
Regards,
Christopher Schmidt
MetaCarta
