[OpenLayers-Users] error in resolution index
from tilecache/geoserver
Lance Dyas
lancelot at inetnebr.com
Sun Nov 25 23:19:07 EST 2007
This is a very hands on issue... with TileCache and it is what I would
say quite fragile.
not nearly as plug and play as its advertised.. you would expect the
extents as advertised
by the WMS in question should be sufficient.. and the default
maxResolution ought to
be something which just works... the openlayers code is very closely
tied to the tilecache
config file .. which sort of feels like ... NOT separating a client
thing and a server thing
Lance Dyas wrote:
> Thanks, rounding things off
> and using extent_type= loose
> did got it covered!
> Christopher Schmidt wrote:
>> On Sun, Nov 25, 2007 at 06:30:27PM -0600, Lance Dyas wrote:
>>> I am getting error of this sort from tilecache...
>>> images are causing this..
>> The most important thing to do is to ensure that the OpenLayers Layer
>> has the same resolutions and bounding box as your TileCache layer. You
>> can define the resolutions in OpenLayers via the 'resolutions' option or
>> the 'maxResolution' option on the layer. The maxExtent should be defined
>> to match the bbox parameter of the TileCache layer.
>> If you are using TileCache for overlays, you should set the 'reproject'
>> option on the layer to 'false'.
>> Regards,
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
