[OpenLayers-Users] kml offline
MilesTogoe
miles.togoe at gmail.com
Wed May 7 15:16:36 EDT 2008
Christopher Schmidt wrote:
> On Wed, May 07, 2008 at 11:44:48AM -0600, MilesTogoe wrote:
>> Does the kml feature display all of the "new open" kml standard ?
> No. Nor does i display all of *any* KML standard.
well I meant now that KML is a standard of the OGC (I didn't know if it
changed from the Google code).
>> Does the kml display work offline ?
> To the same extent it will online, yes. If your KML references online
> content (like icons), those will not be visible if you are offline.
sure, I understand
>> When I'm offline, the kml example seems to show a few polylines but
>> does not show all the polylines in the file and does not have the
>> popups working (v 2.6)
> You say 'the KML example'. Which one? There is no KML example with
> polylines and popups, as far as I know.
well whatever you call this one:
41 KML Layer Example kml-layer.html
<http://www.openlayers.org/dev/examples/kml-layer.html>
I thought lines.kml had a couple of popups.
