[OpenLayers-Users] OpenLayers Map of building *interior*
Paul Spencer
pagameba at gmail.com
Thu May 8 13:13:14 EDT 2008
Hi Alex,
check out this demo:
http://tilecache.org/demos/mario.html
Basically, you don't have to do anything different. You need a tile
source and a reference system which can be just pixels.
There is an image layer example in openlayers that you can use, you
would just set the extent to be 0,0,<widthofimage>,<heightofimage> and
put points on interest on at specific pixel coordinates (even though
you are using the LonLat class, its just a position and doesn't
require real coordinates)
Cheers
Paul
On 8-May-08, at 11:42 AM, Alexander Schwartz wrote:
> Hello All!
> You have a great community here for openlayers users. I have a
> question, if anyone knows of a way to accomplish what I want to do.
> Basically I want to make a map of our office building, as the
> interior is highly complex (none of the hallways are parallel nor
> perpendicular to the exterior walls!). So I am aiming to create a 3d
> scene of the building with the roof cut off, and then place that as
> a 'background', so I can then set up points of interest on the map.
> The end goal is to help new employees find their way around the
> building, as most people get lost, even if they've been here a few
> weeks/months :)
> So can I make OpenLayers skip the whole GPS-based earth map and use
> my own flat scene as a background on which I can start building my
> map? The whole thing should be deceptively simple and will use only
> select features from OL.
> I'm a beginner but am not afraid to go through tutorials and explore
> on my own, so any help would be appreciated. Thank you.
> -Alex
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
