[OpenLayers-Users] Beginner Virtual Earth Problems
Richard Marsden
richard at winwaed.com
Wed May 14 14:34:39 EDT 2008
Yes I now have two separate pages. The example URLs in my earlier
message will be broken now.
That works but there are some bugs.
The base layer switching still doesn't work - having two pages is merely
a work around.
I've also found a problem with Firefox (but not IE). My OpenLayer's div
has a 100% width setting (in CSS). This works fine for the other layers,
but the VE layer does not respect it and appears to use a default fixed
setting.
Overriding a fixed width for the div appears to work, but this doesn't
fit with my site style/template very well!
And another issue is that only v3 & v4 are supported - both are being
retired by Microsoft at the end of August. I've filed a ticket on this one.
For positive news, I've also sent a "how to" article to ViaVirtualEarth.
My maps are at:
http://www.ecomapcostarica.com/map/index.shtml
http://www.ecomapcostarica.com/map/index_ve.shtml
We hope to have some updates (map updates and student blogs) whilst
we're out in the field from the 27th onwards.
Richard Marsden
Winwaed Software Technology LLC
http://www.winwaed.com
http://www.mapping-tools.com
getdano wrote:
> I am experiencing the same behavior. The VE Layer works great by itself but
> as soon as you select another base layer, selecting the VE layer does not
> bring it back.
> I don't believe this was a problem in the previous version of OpenLayers. In
> fact, I replaced the 2.6 lib files with the 2.5 lib files and the base
> layers example works fine with the older lib.
> Is there some change that I have missed in the upgrade? Any advice would be
> greatly appreciated.
> Richard Marsden-119 wrote:
>> I am currently using MapServer and OpenLayers for an online mapping
>> project to display a rain forest study area - unfortunately I'm a bit
>> of a beginner with both! I'm currently having problems using Virtual
>> Earth in OpenLayers: in particular switching between layers, and with VE
>> versions.
>> Virtual Earth isn't suitable for the main map because our study area is
>> only about 10ha of Costa Rican rain forest - ie. the detail just isn't
>> there. However, I am try to use Virtual Earth as an optional base map to
>> show the study area in context.
>> I've managed to get the OpenLayers Virtual Earth sample working with a
>> MapServer WMS hydrology overlay ('synthetic streams').
>> I'm currently trying to get it to work with an alternative "outline map".
>> Ie. there are two base layers that can be chosen with a pair of radio
>> buttons in the LayerSwitcher: 'Virtual Earth Base Layer', and
>> 'Outline' (WMS delivered shape file)
>> An optional overlay is selected with a checkbox: 'Synthetic streams'
>> (also via WMS).
>> This is a work in progress so the colours could be improved, but my
>> results are here:
>> http://www.ecomapcostarica.com/map/map_beta.html
>> Virtual Earth imagery loads okay at first. Switching to the 'Outline'
>> works as well. However, when I switch back to Virtual Earth, it fails to
>> re-appear. Instead, Outline is replaced with a white fill.
>> What am I doing wrong? Or is this kind of behaviour not supported?
>> This is my Javascript:
>> <script
>> src="http://dev.virtualearth.net/mapcontrol/v3/mapcontrol.js"></script>
>> <script src="./OpenLayers.js"></script>
>> <script type="text/javascript">
>> var lon = -84;
>> var lat = 10;
>> var zoom = 7;
>> var map;
>> var stream_layer, velayer, bound_layer, outline_layer;
>> function init(){
>> map = new OpenLayers.Map( 'map' );
>> velayer = new OpenLayers.Layer.VirtualEarth("Virtual Earth
>> Base Layer",
>> { minZoomLevel: 4, maxZoomLevel: 8, 'type': VEMapStyle.Aerial } );
>> map.addLayer(velayer);
>> outline_layer = new OpenLayers.Layer.MapServer( "Outline",
>> "http://www.ecomapcostarica.com/map/mapserv.cgi?map=/usr/home/winwaed/mapdata/cr_outline.map",
>> {layers: 'outline'},
>> {gutter: 15});
>> map.addLayer(outline_layer);
>> stream_layer = new OpenLayers.Layer.MapServer( "Synthetic
>> Streams",
>> "http://www.ecomapcostarica.com/map/mapserv.cgi?map=/usr/home/winwaed/mapdata/cr_stream.map",
>> {layers: 'streams', transparent:'true'},
>> {gutter: 15});
>> map.addLayer(stream_layer);
>> map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>> map.addControl( new OpenLayers.Control.LayerSwitcher() );
>> </script>
>> I've also tried changing the script to use v6.1 of the Virtual Earth
>> Control, ie.:
>> <script
>> src="http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1"></script>
>> The results can be seen here:
>> http://www.ecomapcostarica.com/map/map_ve.html
>> The default "North America" map appears - not my selected area at all,
>> and none of the OpenLayers controls (zoom, layer selection, etc) appear.
>> Is v3 the latest version supported by OpenLayers? Are there any plans
>> to update this in the near future? I see that Microsoft are actively
>> retiring old versions of the Virtual Earth API.
>> Thanks in advance. OpenLayers and MapServer are both capable of some
>> pretty neat stuff - I have high hopes regarding the final result!
>> Richard Marsden
>> Wiwnaed Software Technology LLC
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080514/106f82b2/attachment.html
