[OpenLayers-Users] OL 2.7 Marjers Feature Style_map
Walter Lorenzetti
lorenzetti at gis3w.it
Fri Oct 10 02:14:15 EDT 2008
Eric Lemoine ha scritto:
> Actually, setting multiple to true in the options object passed to the
> select feature control constructor should do the trick. Eric
Thanks a lot Eric... I watch to select feature control code
to find a solution!!
Bye
W
> 2008/10/9, Eric Lemoine <eric.c2c at gmail.com>:
>> Hi.
>> StyleMap applies to Layer.Vector only.
>> I'm not sure I understand your problem with vector feature selection.
>> You want to be able to select one feature without unselecting other
>> selected features; is that it?
>> With the select feature control you can do that with some option and
>> by pressing the SHIFT key during selection. I'm not sure you can
>> configure the select feature control to enable multi selection without
>> having to press any modifier key (I have to check); if not it
>> shouldn't be that hard to build your own select feature control. Look
>> at the select feature control code if you want to follow that path.
>> Cheers
>> Eric
>> 2008/10/9, Walter Lorenzetti <lorenzetti at gis3w.it>:
>>> Hi all,
>>> I don't know if is it possible:
>>> watching on news 2.7 example I found markers_shadow.html
>>> Is fantastic for my new application where now I use icon image just with
>>> shadow...
>>> I see that now is possible to setup a stylemap obj for a vector layer ong
>>> but I've a problem
>>> in my application I parse a gml file to put a markers layer on the map:
>>> 1) I parse the gml file
>>> 2) I build several OpenLayers.Feature obj
>>> 3) I add several metadata from parse file to my new features and new
>>> icon on .data.icon and a popup object
>>> 4) from the new features I build markes
>>> 5) for every marker I register a function on click event
>>> marker.events.register ("click") for show a popup
>>> 6) at the end I put all my new markers in a mew marker layer obj
>>> I do that because on a more simple vector layer is too difficult
>>> register a click event
>>> because I can only select the single feature...
>>> so my question is:
>>> Is possible apply the stylemap method to a OpenlayersFeature?
>>> Or with a vector layer obj is there a symple method for a click event?
>>> I hope my english is not too bad
>>> Thanks in advance
>>> Walter
>>> Walter Lorenzetti
>>> email: lorenzetti at gis3w.it
>>> skype: aiki74
>>> Cell: (+39) 347-6597931 Tel+Fax: (+39) 0583 926684
>>> Via di Tofori 123a 55010, Camigliano-S.Gemma Lucca
>>> Italy
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
Walter Lorenzetti
skype: aiki74
Italy
