[OpenLayers-Users] failure on re-opening a popup
kmalk kmalkowski at sourcepark.de
Wed Aug 26 09:37:09 EDT 2009
Hi!
I have a map with icons, which create a popup when mouseClicked on it.
They close themselves, when a mouseClick is done on closeButton or the icon.
With this.layer.map.addPopup(this.createPopup(true), true); I create the
popup (1st para)
and close (if existing) other popups (2nd para).
everything works fine ..except one thing:
after clicking many (different) icons, all opened popups will not pop up
again.:-/
Has someone an idea how to change this behavior?
View this message in context: http://n2.nabble.com/failure-on-re-opening-a-popup-tp3514981p3514981.html
