[OpenLayers-Users] Support for Cursors?
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Jul 2 12:18:24 EDT 2009
Hi Bill,
please try:
.olControlPanel .olInfoItemActive {
background-image: url("../img/info-on.png");
.olInfoItemActive {
cursor: pointer;
Best regards,
Bart
Bill Thoen wrote:
> I'm not sure either. Here's how I'm setting display classes for the info
> tool (as an example). This shows the pointer cursor , but only when you
> hover over the tool icon on the control panel:
> cursor: pointer;
> And I add the array of tools to the panel like so:
> // Info Tool
> toolButtons[9] = new OpenLayers.Control.FeatureInfo(
> {title:"Get feature information", "displayClass": "olInfo",
> "showMarker" : false};
> // Add the control panel
> var toolArray = [];
> for( var i=0; i<toolz.length; i++) {
> toolArray[i] = toolButtons[toolz[i]];
> var panel = new OpenLayers.Control.Panel({ div : tool_div });
> panel.addControls( toolArray );
> this.map.addControl( panel );
> (the integer array toolz[] that indexs the array of tool objects
> (toolsArray) is just a device that allows me to work with a subset of
> the tools that I have and also put them in a particular order. I don't
> think this has anything to do with it, but I explain it 'cause it's a
> bit weird.)
> As far as I can tell, the map window's div displayClass is null. What
> should it be, or am I barking up the wrong tree?
> -Bill
> Bart van den Eijnden (OSGIS) wrote:
>> Hi Bill,
>> not sure, can you check the css class which has been set on the map
>> viewport div when you activate a tool? They should have those values.
>> Maybe there is another class which is preventing the cursors from
>> showing up.
>> Best regards,
>> Bart
>> Bill Thoen wrote:
>>> Thanks Bart, but for some reason this changes the cursor only over
>>> the tool buttons on the control panel. How do I make it extend over
>>> my map window when I change tools?
>>> bartvde at osgis.nl wrote:
>>>> Hi Bill,
>>>> yes it's in 2.8.
>>>> You need to add css classes depending on the displayClass + "Active"
>>>> of a control, e.g. this is what I have:
>>>> .olControlDragPanActive {
>>>> cursor: url(lib/openlayers/theme/default/img/pan.cur) 16 16,
>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/pan.cur), auto;
>>>> .olControlZoomBoxActive {
>>>> cursor: url(lib/openlayers/theme/default/img/zoomin.cur) 9 9,
>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/zoomin.cur),
>>>> auto;
>>>> .zoomoutActive {
>>>> cursor: url(lib/openlayers/theme/default/img/zoomout.cur) 9 9,
>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/zoomout.cur),
>>>> auto;
>>>> .olControlDragPanActive.olDragDown {
>>>> cursor: url(lib/openlayers/theme/default/img/pandown.cur) 16 16,
>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/pandown.cur),
>>>> auto;
>>>> .GeoServicesControlSLDSelectActive {
>>>> cursor: default;
>>>> .GeoServicesControlFeatureInfoActive {
>>>> cursor: pointer;
>>>> .olControlMeasureActive {
>>>> cursor: crosshair;
>>>> .olControlDrawFeaturePolygonActive {
>>>> cursor: crosshair;
>>>> .olControlDrawFeaturePointActive {
>>>> cursor: crosshair;
>>>> .olControlDrawFeaturePathActive {
>>>> cursor: crosshair;
>>>> cursor: crosshair;
>>>> cursor: crosshair;
>>>> cursor: crosshair;
>>>> Hope this helps.
>>>> Best regards,
>>>> Bart
>>>>> Was support for using different cursor icons (pointer, text, wait,
>>>>> etc.)
>>>>> built into version 2.8? I didn't see anything about cursors in the
>>>>> release notes but I thought there had been some work done on this.
>>>>> If not, can someone tell me the best place to set the cursor icon for
>>>>> tool buttons? Is there an "on activate" event I can listen for, or is
>>>>> there a better way to do this?
>>>>> Thx,
>>>>> - Bill Thoen
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
