[OpenLayers-Users] Support for Cursors?
Bill Thoen
bthoen at gisnet.com
Thu Jul 2 12:39:01 EDT 2009
Not quite. Now the cursor still appears only over the tool, but only
after I activate it. As soon as I move off the icon it reverts to the
default arrow cursor. Unless you have (or anyone else has) any other
ideas, maybe I'll try a dead-simple OL scrapplication with a basic map
and one tool and see if I can get that to work. At least then if it
doesn't work I'll have some source code to share, and if it does work,
then I'll have a new problem of figuring out what I screwed up in my
real application.
- Bill
Bart van den Eijnden (OSGIS) wrote:
> Hi Bill,
> please try:
> .olControlPanel .olInfoItemActive {
> background-image: url("../img/info-on.png");
> .olInfoItemActive {
> cursor: pointer;
> Best regards,
> Bart
> Bill Thoen wrote:
>> I'm not sure either. Here's how I'm setting display classes for the
>> info tool (as an example). This shows the pointer cursor , but only
>> when you hover over the tool icon on the control panel:
>> cursor: pointer;
>> And I add the array of tools to the panel like so:
>> // Info Tool
>> toolButtons[9] = new OpenLayers.Control.FeatureInfo(
>> {title:"Get feature information", "displayClass": "olInfo",
>> "showMarker" : false};
>> // Add the control panel
>> var toolArray = [];
>> for( var i=0; i<toolz.length; i++) {
>> toolArray[i] = toolButtons[toolz[i]];
>> var panel = new OpenLayers.Control.Panel({ div : tool_div });
>> panel.addControls( toolArray );
>> this.map.addControl( panel );
>> (the integer array toolz[] that indexs the array of tool objects
>> (toolsArray) is just a device that allows me to work with a subset of
>> the tools that I have and also put them in a particular order. I
>> don't think this has anything to do with it, but I explain it 'cause
>> it's a bit weird.)
>> As far as I can tell, the map window's div displayClass is null.
>> What should it be, or am I barking up the wrong tree?
>> -Bill
>>> Hi Bill,
>>> not sure, can you check the css class which has been set on the map
>>> viewport div when you activate a tool? They should have those
>>> values. Maybe there is another class which is preventing the cursors
>>> from showing up.
>>> Best regards,
>>> Bart
>>> Bill Thoen wrote:
>>>> Thanks Bart, but for some reason this changes the cursor only over
>>>> the tool buttons on the control panel. How do I make it extend over
>>>> my map window when I change tools?
>>>> bartvde at osgis.nl wrote:
>>>>> Hi Bill,
>>>>> yes it's in 2.8.
>>>>> You need to add css classes depending on the displayClass + "Active"
>>>>> of a control, e.g. this is what I have:
>>>>> .olControlDragPanActive {
>>>>> cursor: url(lib/openlayers/theme/default/img/pan.cur) 16 16,
>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/pan.cur),
>>>>> auto;
>>>>> .olControlZoomBoxActive {
>>>>> cursor: url(lib/openlayers/theme/default/img/zoomin.cur) 9 9,
>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/zoomin.cur),
>>>>> auto;
>>>>> .zoomoutActive {
>>>>> cursor: url(lib/openlayers/theme/default/img/zoomout.cur) 9 9,
>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/zoomout.cur),
>>>>> auto;
>>>>> .olControlDragPanActive.olDragDown {
>>>>> cursor: url(lib/openlayers/theme/default/img/pandown.cur) 16 16,
>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/pandown.cur),
>>>>> auto;
>>>>> .GeoServicesControlSLDSelectActive {
>>>>> cursor: default;
>>>>> .GeoServicesControlFeatureInfoActive {
>>>>> cursor: pointer;
>>>>> .olControlMeasureActive {
>>>>> cursor: crosshair;
>>>>> .olControlDrawFeaturePolygonActive {
>>>>> cursor: crosshair;
>>>>> .olControlDrawFeaturePointActive {
>>>>> cursor: crosshair;
>>>>> .olControlDrawFeaturePathActive {
>>>>> cursor: crosshair;
>>>>> cursor: crosshair;
>>>>> cursor: crosshair;
>>>>> cursor: crosshair;
>>>>> Hope this helps.
>>>>> Best regards,
>>>>> Bart
>>>>>> Was support for using different cursor icons (pointer, text,
>>>>>> wait, etc.)
>>>>>> built into version 2.8? I didn't see anything about cursors in the
>>>>>> release notes but I thought there had been some work done on this.
>>>>>> If not, can someone tell me the best place to set the cursor icon
>>>>>> for
>>>>>> tool buttons? Is there an "on activate" event I can listen for,
>>>>>> or is
>>>>>> there a better way to do this?
>>>>>> Thx,
>>>>>> - Bill Thoen
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
