[OpenLayers-Users] Support for Cursors?
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Jul 2 12:38:15 EDT 2009
I now see that your displayClass is olInfo, so you need to use
olInfoActive for the map cursor:
   .olControlPanel .olInfoItemActive {
      background-image: url("../img/info-on.png");
   .olInfoActive {
      cursor: pointer;
Best regards,
Bart
Bill Thoen wrote:
> Not quite. Now the cursor still appears only over the tool, but only
> after I activate it. As soon as I move off the icon it reverts to the
> default arrow cursor. Unless you have (or anyone else has) any other
> ideas, maybe I'll try a dead-simple OL scrapplication with a basic map
> and one tool and see if I can get that to work. At least then if it
> doesn't work I'll have some source code to share, and if it does work,
> then I'll have a new problem of figuring out what I screwed up in my
> real application.
> - Bill
> Bart van den Eijnden (OSGIS) wrote:
>> Hi Bill,
>> please try:
>>   .olInfoItemActive {
>>      cursor: pointer;
>> Best regards,
>> Bart
>> Bill Thoen wrote:
>>> I'm not sure either. Here's how I'm setting display classes for the
>>> info tool (as an example). This shows the pointer cursor , but only
>>> when you hover over the tool icon on the control panel:
>>>       cursor: pointer;
>>> And I add the array of tools to the panel like so:
>>>      // Info Tool
>>>       toolButtons[9] = new OpenLayers.Control.FeatureInfo(
>>>          {title:"Get feature information", "displayClass": "olInfo",
>>> "showMarker" : false};
>>>       // Add the control panel
>>>       var toolArray = [];
>>>       for( var i=0; i<toolz.length; i++) {
>>>          toolArray[i] = toolButtons[toolz[i]];
>>>       var panel = new OpenLayers.Control.Panel({ div : tool_div });
>>>       panel.addControls( toolArray );
>>>       this.map.addControl( panel );
>>> (the integer array toolz[] that indexs the array of tool objects
>>> (toolsArray) is just a device that allows me to work with a subset of
>>> the tools that I have and also put them in a particular order. I
>>> don't think this has anything to do with it, but I explain it 'cause
>>> it's a bit weird.)
>>> As far as I can tell, the map window's div  displayClass is null.
>>> What should it be, or am I barking up the wrong tree?
>>> -Bill
>>>> Hi Bill,
>>>> not sure, can you check the css class which has been set on the map
>>>> viewport div when you activate a tool? They should have those
>>>> values. Maybe there is another class which is preventing the cursors
>>>> from showing up.
>>>> Best regards,
>>>> Bart
>>>> Bill Thoen wrote:
>>>>> Thanks Bart, but for some reason this changes the cursor only over
>>>>> the tool buttons on the control panel. How do I make it extend over
>>>>> my map window when I change tools?
>>>>> bartvde at osgis.nl wrote:
>>>>>> Hi Bill,
>>>>>> yes it's in 2.8.
>>>>>> You need to add css classes depending on the displayClass + "Active"
>>>>>>  of a control, e.g. this is what I have:
>>>>>> .olControlDragPanActive {
>>>>>>     cursor: url(lib/openlayers/theme/default/img/pan.cur) 16 16,
>>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/pan.cur),
>>>>>> auto;
>>>>>> .olControlZoomBoxActive {
>>>>>>     cursor: url(lib/openlayers/theme/default/img/zoomin.cur) 9 9,
>>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/zoomin.cur),
>>>>>> auto;
>>>>>> .zoomoutActive {
>>>>>>     cursor: url(lib/openlayers/theme/default/img/zoomout.cur) 9 9,
>>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/zoomout.cur),
>>>>>> auto;
>>>>>> .olControlDragPanActive.olDragDown {
>>>>>>     cursor: url(lib/openlayers/theme/default/img/pandown.cur) 16 16,
>>>>>> url(../geoservices2.2/lib/openlayers/theme/default/img/pandown.cur),
>>>>>> auto;
>>>>>> .GeoServicesControlSLDSelectActive {
>>>>>>     cursor: default;
>>>>>> .GeoServicesControlFeatureInfoActive {
>>>>>>     cursor: pointer;
>>>>>> .olControlMeasureActive {
>>>>>>     cursor: crosshair;
>>>>>> .olControlDrawFeaturePolygonActive {
>>>>>>     cursor: crosshair;
>>>>>> .olControlDrawFeaturePointActive {
>>>>>>     cursor: crosshair;
>>>>>> .olControlDrawFeaturePathActive {
>>>>>>     cursor: crosshair;
>>>>>>     cursor: crosshair;
>>>>>>     cursor: crosshair;
>>>>>>     cursor: crosshair;
>>>>>> Hope this helps.
>>>>>> Best regards,
>>>>>> Bart
>>>>>>> Was support for using different cursor icons (pointer, text,
>>>>>>> wait, etc.)
>>>>>>> built into version 2.8? I didn't see anything about cursors in the
>>>>>>> release notes but I thought there had been some work done on this.
>>>>>>> If not, can someone tell me the best place to set the cursor icon
>>>>>>> for
>>>>>>> tool buttons? Is there an "on activate" event I can listen for,
>>>>>>> or is
>>>>>>> there a better way to do this?
>>>>>>> Thx,
>>>>>>> - Bill Thoen
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
