[OpenLayers-Users] Google Maps map does not reflect zoom level change
Axel Müller axel.mueller at avanux.de
Mon Jul 6 14:46:20 EDT 2009
Andrea,
Andreas Hocevar wrote:
>> Based on some parameters I change the zoom level using
>> map.setCenter(lonlat, zoom).
>> This works perfectly for OSM Mapnik layer but not for Google layer where
>> the pan zoom bar reflects the new zoom level but the map itself still
>> shows the previous zoom level. Am I missing something?
>> osmLayer = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
>> gMapLayer = new OpenLayers.Layer.Google("Google Maps", {numZoomLevels:
>> 20, isBaseLayer: true });
> Using Google layers like this only works in a few use cases. You have
> to use Spherical Mercator to make it behave like you are expecting.
> See http://docs.openlayers.org/library/spherical_mercator.html for
> explanation, tutorial and howto.
Thanks for pointing me to this documentation. I'm using Spherical
Mercator now but the underlying problem is still the same:
While being on the Google layer, a call to
map.setCenter(lastMarker.lonlat, zoom) causes the zoom bar to show the
new zoom level but the map is still displayed for the previously
selected zoom level.  If I switch to OSM layer and back to Google layer,
the map in the Google layer is shown with the correct zoom level,
matching the zoom level indicated by the zoom bar.
Best regards,
Axel
Below is the relevant part of JS:
    function init() {
        map = new OpenLayers.Map('map', {
            projection: new OpenLayers.Projection("EPSG:900913"),
            displayProjection: new OpenLayers.Projection("EPSG:4326"),
            units: "m",
            controls: [
                new OpenLayers.Control.Navigation(),
                new OpenLayers.Control.PanZoomBar(),
                new OpenLayers.Control.LayerSwitcher({'ascending':false}),
                new OpenLayers.Control.Permalink(),
                new OpenLayers.Control.ScaleLine(),
                new OpenLayers.Control.Permalink('permalink'),
                new OpenLayers.Control.MousePosition(),
                new OpenLayers.Control.OverviewMap(),
        var gMapLayer = new OpenLayers.Layer.Google("Google Maps",
{isBaseLayer: true, 'sphericalMercator': true });
        var osmLayer = new OpenLayers.Layer.OSM();
        map.addLayers([gMapLayer, osmLayer]);
        map.zoomTo(zoom);
    function triggerUpdate() {
        triggerUpdateActive = true;
        window.setTimeout("update()", refreshSeconds * 1000);
    function update() {
        triggerUpdate();
        if(rss != null) {
            rss.destroy();
        rss = new OpenLayers.Layer.GeoRSS(trackingID, geoRssUrl,
{'projection': new OpenLayers.Projection("EPSG:4326")} );
        rss.events.register("loadend", window, populateMap);
        map.addLayer(rss);
    function populateMap() {
        if(rss.markers.length >= 1) {
            var lastMarker=rss.markers[rss.markers.length-1];
            map.setCenter(lastMarker.lonlat, zoom);
       map.raiseLayer(rss, 1);
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090706/21d3961a/attachment.html
