[OpenLayers-Users] Google Maps map does not reflect zoom level
change
Axel Müller
axel.mueller at avanux.de
Sat Jul 11 00:15:16 EDT 2009
Just in case somebody is having the same problem. Center/zoom works well
for all layers using the code below:
function init() {
map = new OpenLayers.Map('map', {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
numZoomLevels: 20,
controls: [
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.LayerSwitcher(),
new OpenLayers.Control.Permalink(),
new OpenLayers.Control.ScaleLine(),
var osmLayer = new OpenLayers.Layer.OSM.Mapnik("OpenStreetMap");
var gMapLayer = new OpenLayers.Layer.Google("Google", {sphericalMercator:true});
var gPhysicalLayer = new OpenLayers.Layer.Google("Google Physical", {type: G_PHYSICAL_MAP, sphericalMercator:true});
var gSatelliteLayer = new OpenLayers.Layer.Google("Google Satellite", {type: G_SATELLITE_MAP, sphericalMercator:true});
map.addLayers([osmLayer, gMapLayer, gPhysicalLayer, gSatelliteLayer]);
map.zoomTo(zoom);
function triggerUpdate() {
triggerUpdateActive = true;
window.setTimeout("update()", refreshSeconds * 1000);
function update() {
triggerUpdate();
if(rss != null) {
rss.destroy();
rss = new OpenLayers.Layer.GeoRSS(trackingID, geoRssUrl, {'projection': new OpenLayers.Projection("EPSG:4326")} );
rss.events.register("loadend", window, populateMap);
map.addLayer(rss);
function populateMap() {
map.zoomTo(zoom);
if(rss.markers.length >= 1) {
var lastMarker=rss.markers[rss.markers.length-1];
map.setCenter(lastMarker.lonlat);
map.raiseLayer(rss, 1);
Regards,
Axel
> Andrea,
> Andreas Hocevar wrote:
>>> Based on some parameters I change the zoom level using
>>> map.setCenter(lonlat, zoom).
>>> This works perfectly for OSM Mapnik layer but not for Google layer where
>>> the pan zoom bar reflects the new zoom level but the map itself still
>>> shows the previous zoom level. Am I missing something?
>>> osmLayer = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
>>> gMapLayer = new OpenLayers.Layer.Google("Google Maps", {numZoomLevels:
>>> 20, isBaseLayer: true });
>> Using Google layers like this only works in a few use cases. You have
>> to use Spherical Mercator to make it behave like you are expecting.
>> See http://docs.openlayers.org/library/spherical_mercator.html for
>> explanation, tutorial and howto.
> Thanks for pointing me to this documentation. I'm using Spherical
> Mercator now but the underlying problem is still the same:
> While being on the Google layer, a call to
> map.setCenter(lastMarker.lonlat, zoom) causes the zoom bar to show the
> new zoom level but the map is still displayed for the previously
> selected zoom level. If I switch to OSM layer and back to Google
> layer, the map in the Google layer is shown with the correct zoom
> level, matching the zoom level indicated by the zoom bar.
> Best regards,
> Axel
> Below is the relevant part of JS:
> function init() {
> units: "m",
> controls: [
> new OpenLayers.Control.LayerSwitcher({'ascending':false}),
> new OpenLayers.Control.Permalink('permalink'),
> new OpenLayers.Control.MousePosition(),
> new OpenLayers.Control.OverviewMap(),
> var gMapLayer = new OpenLayers.Layer.Google("Google Maps",
> {isBaseLayer: true, 'sphericalMercator': true });
> var osmLayer = new OpenLayers.Layer.OSM();
> map.addLayers([gMapLayer, osmLayer]);
> map.zoomTo(zoom);
> function update() {
> triggerUpdate();
> if(rss != null) {
> rss.destroy();
> map.addLayer(rss);
> map.setCenter(lastMarker.lonlat, zoom);
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090711/74a33e8d/attachment.html
