[OpenLayers-Users] Samples using new ArcGIS JavaScript API in OpenLayers
João Domingues jdomingues at sinfic.pt
Fri Jul 10 10:13:53 EDT 2009
firstly, I'm sorry if this got in the wrong place, I'm not sure where to
post this
I've been trying to use your 2.8+ sandbox to connect to an arcgis server.
I've finally got it even with internet explorer, using your example
wfs = new OpenLayers.Layer.Vector(
					"arcgis server wfs ",
						strategies: [
								bbox_strategy,
								lock_strategy,
								save_strategy
						protocol: new OpenLayers.Protocol.WFS2({
Now i'm trying to use the same code to connect to a geoserver. The idea is
to have map editing functionality in a web application, able to work with
both geoserver & arcgisServer. But i got the following error when inserting
to geoserver:
<!-- insert will generate error -->
	<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs"
		service="WFS" version="1.1.0" releaseAction="ALL">
		<wfs:Insert>
			<wfs:tasmania_cities>
				<wfs:the_geom>
					<gml:Point xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">
						<gml:pos>145.89146484375 -43.1480859375</gml:pos>
					</gml:Point>
				</wfs:the_geom>
			</wfs:tasmania_cities>
		</wfs:Insert>
	</wfs:Transaction>
<!--insert error response -->
	<ows:ExceptionReport version="1.0.0"
		xsi:schemaLocation="http://www.opengis.net/ows
http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
		xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ows="http://www.opengis.net/ows">
		<ows:Exception exceptionCode="NoApplicableCode">
			<ows:ExceptionText>
				java.io.IOException: Current fid index is null, next must be called
before write()
				Current fid index is null, next must be called before write()
			</ows:ExceptionText>
		</ows:Exception>
	</ows:ExceptionReport>
when using the same code with arcgisServer, the following insert
	<!-- insert ok -->
		version="1.0.0" service="WFS">
		<wfs:Insert>
			<feature:tasmania_cities xmlns:feature="http://www.openplans.org/topp">
				<feature:the_geom>
					<gml:MultiPoint xmlns:gml="http://www.opengis.net/gml">
						<gml:pointMember>
							<gml:Point>
								<gml:coordinates decimal="." cs="," ts=" ">
									147.407578125,-41.7418359375</gml:coordinates>
							</gml:Point>
						</gml:pointMember>
					</gml:MultiPoint>
				</feature:the_geom>
			</feature:tasmania_cities>
		</wfs:Insert>
	</wfs:Transaction>
works fine. Moreover, after the error with geoserver, the wfs service
stopped responding. I'm using the default tasmania_ layers.
I'd like to know if you can help me with this particular error but also aid
me with a few pointers:
1) do you think this is the right/best way of doing it, or do you have other
sugestions?
2)does your sandbox/2.8+ breaks support for geoserver? i see it extending
wfs2protocol from wfsprotocol...
3) do you know if openlayers will integrate support for arcgis server?
4) if you can direct me to other sources of information on this, it would be
most welcome :)
View this message in context: http://n2.nabble.com/Samples-using-new-ArcGIS-JavaScript-API-in-OpenLayers-tp1829224p3236641.html
