[OpenLayers-Users] Popup in Openlayers (How to fix the popup?)
Kwong Hu Kiu kwonghu at hotmail.com
Thu Jul 16 13:41:25 EDT 2009
 Any example ? I have the map as a fullscreen.
Thanks.
To: kwonghu at hotmail.com
Subject: AW: [OpenLayers-Users] Popup in Openlayers (How to fix the popup?)
Date: Thu, 16 Jul 2009 18:31:52 +0200
Why do you not create an own div element instead of an
OpenLayers popup? It will always be at the same position without calling
any events.
Arnd
Von: users-bounces at openlayers.org
[mailto:users-bounces at openlayers.org] Im Auftrag von Kwong Hu
Kiu
Gesendet: Donnerstag, 16. Juli 2009 16:32
An:
adube at mapgears.com
Cc: users at openlayers.org
Betreff: Re:
popup?)
Yes, the moveend is triggered on every pan but it's not moving
the popup.
The popup.moveto is always being called.
Any idea
> Date: Thu, 16 Jul 2009 09:45:34 -0400
> From:
> CC:
> Subject: Re: [OpenLayers-Users] Popup in Openlayers
> Hi,
> Could you share
more of your code, please ? How do you register you
> event for instance
? The 'moveend' event should be triggered on every pan.
Regards,
> Alexandre
> Kwong Hu Kiu wrote:
> > I have tried that.
Something like
> > if (popup != null)
> > var widthPixel = map.getSize().w - 280;
> var heightPixel = map.getSize().h - 300;
> > popup.moveTo(new
OpenLayers.Pixel(widthPixel,
> > heightPixel));
> > But the popup does not want to move when i pan.
It only move if i zoom in/out.
> > I have debug'ed this and
"pop.moveTo" is being called whenever i pan.
> > Not
really sure if this is a bug.
> > I just want a simple
popup that always appear on the lower right corner
> > so user can
interact with the map.
> > Regards.
> > > Date: Thu, 16 Jul 2009 08:18:27 -0400
> CC: users at openlayers.org
> > popup?)
> > > Hi,
> > > You could
register a map 'moveend' event to move the popup again to
> > > the
original location. You would need to recalculate the position on
> each move.
> > > Regards,
> > > Alexandre
> > > Kwong Hu
Kiu wrote:
> > > > Hi,
> I am trying to use the openlayers popup in the map as below.
> > > > if (this.popup == null)
> > > > this.popup = new OpenLayers.Popup();
> this.popup.setBorder("2px solid");
this.popup.setSize(new OpenLayers.Size(270, 270));
this.popup.setContentHTML(popupContentHTML);
this.popup.setOpacity(0.65);
this.popup.addCloseBox();
map.addPopup(this.popup);
> > > > this.popup.show();
> > > > else
this.popup.toggle();
> > > > How do i get it to display in one position
(like the lower left
> > > > portion of the screen) ? and always
appear there whenever you pan/zoom
I figured that i can use popup.moveTo as below.
this.popup.moveTo(new OpenLayers.Pixel(widthPixel, heightPixel));
> > > > But the popup will move out of that location
whenever you pan. It's
> > > > alright when you zoom
in/out(always at the lower left) but not pan.
> > > Please help. Simple problem taking me a while to resolve.
> > > > Cheers.
> > > > Users
> > > > Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
> > > Alexandre
Dubé
> > > Mapgears
> > > www.mapgears.com
> Alexandre Dubé
Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090717/3d91736e/attachment.html
